Yes i used the search function and i still cannot find a lighting diagram. I know how to hook up the relays that not a problem for me, I tested the voltage drop at the bulb and i was getting 13.8 volts which i think is very good i try and took the bulb up to the accessories line on the alternator just to see how bright it get compared to the 13.8 volts.
Anyway, I have at the moment 100W on high beam and a 90W low beam.
I had a 150W in at one time but the entire bulb melted from the heat the lamp couldn't dissipate the heat the bulb generated.
I believe my surf is 1992.
nach.
 S'fair enough!!
