If the light on the dash works then chances are you will have power past the fuse.
Most likely cause is a broken cable. (assuming it's a second gen with drop down tailgate)
Open tailgate. look to the left hand side. there is a plastic sheath , covering a whole bunch of cables.
These exit the tailgate and go up into the rear wing of the truck. Most braekages occur in the bit you can get at.
Take the sheathing off and use Alabannach's excellent trick of sticking a pin in the cable to test continuity (along with a multimeter or a battery and bulb setup)
Hope you find it
Alan
Hope you find it
Alan
