I fitted a new Sony head unit some time ago without too much trouble, I just used a Toyota - ISO and then a ISO - SONY connector.
However I recently bought a motoriszed touchscreen which I want to mount in the second DIN bracket above my Sony headunit. How should I go about powering this? Can I simply split the +12V cable and the ground cable inbetween say the ISO connection and the Sony connection and use these to power the screen and the headunit?
Also, I presume that i'll need to uprate the fuse too? (Which I presume can be found in the regular fuse box?)
