Hi, recently bought a ssrx limited. Switches from 2wd to 4wd ok but the 4wd light is constantly lit. Clock doesnt work either, everything else seems ok. Anyone have any ideas? Cheers.
4wd operation light problem
afternoon all
recently had a similar problem on my 3rd gen. It has recently spent a lot of time not only in H4L but also in L4L (both used my moving the transfer lever.
When I went back into H2 H4 and tried to selct 4WD by using the little buttin on the lever it would not come out of 4WD for ages.
Every time I started the car, normally in 2WD the 4 little green lights would flash for ages (but not in 4WD).
I solved this by disconnecting both batteries for about 1/2 an hour. Re connected them and everything is back to normal & working perfectly.
hope this helps
ta
hawaiiI'm not overweight, I'm undertall!
