Anyone any ideas what I may or may not have done with my radio/aeriel?
Drove to the shop radio worked fine, came back to the Surf, turned ignition on etc, no aeriel, no radio!
. Its the Sony multi cd/radio system with TA etc, I did have a play the day before trying to familiarise my self with all the buttons, but didn't think I'd altered any thing, but now no station is showing in the display when I try to select tuner, and the aeriel does not come out, tried turning TA on/off, as I read some thread that suggests it is linked to turning the aeriel auto erect on/off, but unless I'm doing it wrong it does not seem to do the trick!
 No previous problems up to date. I put a question to Sounds Digital thread, but I was hopping for a broader response, sorry Sounds Digital, but I will try the fuse you mentioned, not had time to try and check that out yet!
 Does any one know how to check the relay out?
 GOT NO COWBOYS HERE?
  Cracked it!! cheers Charvell, disconecting the battery was the simplest check, and for some reason it worked. Goes up and down like a good 'un now, but I've no idea as to why it stopped working in the first place. Seems like I won't need to take the inner wing off after all, ta for the info Poppy.
