I just got a new headlight wiring loom from 4crawler (the expensive one), what's your recommendations on which lamps to fit. Are 130w H4s available, if so, what's the chances that Mr plod will pull me for using them?
Headlight lamps
you can get H4s upto about 160w if you look around. 130/90 and 100/80 are readily available. If the lenses or reflectors are plastic i wouldn't want to go much over the 100/80ws the extra heat can actually start to melt the light units themselves. I had 100/80 on an uprated loom with no issues at all on my prefacelift 2nd gen, other than nice bright lights that rendered my spotlights virtually useless.=========
=SOLD UP!=
Originally posted by Albannach View PostI'm thinking 100/80s are what I'll use, but would stretch to 130s if I can. Are 2nd gen headlamps plastic?=========
=SOLD UP!=
Originally posted by nero279 View Posti think the post facelift ones are, the early square ones as in my avatar are plastic bowls with glass lenses - but daihatsu used the same lights with metal bowls and glass lenses on their small carry type van Glass lenses don't like being dunked in cold water when they're hot from the bulbs though. So it's all swings and rroundabouts.Do you know that, with a 50 character limit, it's
