I want to make my own tail/break light bar, haveing seen BDT's only with more leds than that contained, how do i wire em so they are not so bright when tail light are on but go to full brightness when breaks are used, i believe useing a high value resistor will "dim" them but what value? the bar i worked on seems to have been made up of banks of four leds controlled by two (different value) risistors, i should have checked the colour codeing but did'nt think and now it's all sealed up, been looking at several google'd sites and it appears you can wire four leds in series without a resistor and am i right in thinking if say five or six were wired the same it would reduce the brightness,
(this is working on led of 3v) any help would be great,
ian
ian
