Have you the wiring diagram for the rear window as mine does not open from the rear door key switch only closes I can open it both ways from the switch in side, ...Have to open from inside so misses gets wet waiting for me to insert key and open door.
Have fitted a new relay box (from another member) today but no good
GWYN - sounds like a broken wire, they break from the constant bending where they go from the body to the tailgate, either that or the keyswitch itself.
Try one of these. http://cgi.ebay.co.uk/CAR-ALARM-IMMO...QQcmdZViewItem
Has a remote for opening the boot lock which can be wired to the back window. Also has loads of other functions. Seems a bargain at £30 but has loads of wires and relays to wire to get all the functions.
