ok surf's own spotlight wiring.my surf has a bull bar and i just fitted spotlights to it using exsiting brakets conected the exsiting wiring up (surf's own wiring) nothing!!! is there a switch or where is the fuse/relay any help please...
spotlight wiring
Originally posted by rally_manok surf's own spotlight wiring.my surf has a bull bar and i just fitted spotlights to it using exsiting brakets conected the exsiting wiring up (surf's own wiring) nothing!!! is there a switch or where is the fuse/relay any help please...
Simple spotlight wiring diagram.........Last edited by BUSHWHACKER; 19 January 2012, 01:37.
Originally posted by rally_manok surf's own spotlight wiring.my surf has a bull bar and i just fitted spotlights to it using exsiting brakets conected the exsiting wiring up (surf's own wiring) nothing!!! is there a switch or where is the fuse/relay any help please...Surf.gone but not forgottendisco now gone aswell
my 2 gen had and my 3 gen has but both are pain as they can be switched on with just the side lights
got a new set of spots so will be fitting them tomoz hopefully and this time i will wire them via a relay and use the hi beam as a trigger wire and go via the dash switch so can isolateSurf.gone but not forgottendisco now gone aswell
sorry peeps but suffering from man's flu.Lreg 3.0td SS-g .so i am
looking for a switch in centre console but you say there is no fuse or relay in this circuit, is that why they have yellow fog lamps as standard .so when i
test i presume that this circuit will become live on dip beam as you can use fog lamps this way .mmmmmm will try tomorrow .been thrown out the pit by the wife coughing to much
Originally posted by rally_mansorry peeps but suffering from man's flu.Lreg 3.0td SS-g .so i am
test i presume that this circuit will become live on dip beam as you can use fog lamps this way .mmmmmm will try tomorrow .been thrown out the pit by the wife coughing to muchSurf.gone but not forgottendisco now gone aswell
Originally posted by rally_manOK put sidelights on in fact put all lights on switched on but sill no power to spot/fog wiring can anyone tell me where fuse/relay is. (mud skipper)
The fuse/relay for the front foglights will be where ever the previous owner fitted it. As I said on the first page, spot/foglights were not fitted as standard to any 2nd gen Surf!
