I have a 2.4TD Toyota Surf LN130 Series. Problem I have a break in the door harness wiring so now i have no electric Window control, door locking etc. Does anyone out there have a wiring diagram or reference chart to the various coloured cables present. This will cut down the time i spend finding the offending cable and insert a patch. I know the harness is at fault because if i push against the bellows in the door hinge area the electrics flicker on and off
Drivers Door Electrics
I had a problem after my windows were tinted.
In the end it was that the plugs had been forced on in the wrong orientation. (hard to explain really, kind of upside down/wrong way round.)
With them forced on they looked OK (fitted snug) and I only discovered they were wrong when I took one off to test for voltage and noticed there was more than one way to put it back..
Good luck.
Phil.
