This is one of those frustrating ones..the sort of thing that's all or nothing..you think it's gone away, then returns to bite yer bum when you've just kinda forgetting about it..
Six, or more weeks ago, i knocked off the immobiliser, put the key in, gave it the usual lag for the plugs to heat up nicely and went to fire her up..a loud clunk as the engine turned briefly, then all was silent once more..i returned the key to the off position, turned it again, all the lights were showing brightly on the dash, glowplug light out..wait...wait..turn, and started without drama..now i'm thinking i imagined it!
three weeks ago..having been fine..again, first start of the day..turn the key.."clunk"..second turn, she kinda rotates, but not enough to explode the fuel..then with the key still wound to the stops, it faded away..the third turn however, resulted in the engine spinning at speed, and lighting on the second turn..now i'm thinking "cracked head, coolant gushing into cylinder head causing the engine to lock on the upstroke of the affected piston..second stroke might have cleared it enough to fire on the third" ok..i've got a vivid imagination, and a capacity to always look on the dark side first..
Recalling my earlier battery saga, i checked the battery contents, attempted to wiggle the tight terminals (the cause of my previous starting issue), then ordered a starter motor repair kit from Roughtrax..
Its been fine, without any further action being neccessary..starts like a demon..except for this morning..again, the first start..no clunk this time..maybe a click from the relay, but not engine or starter..just, erm, nothing..even though the lights are glowing good, and the needle on the volt thingy is pointing in the right direction..second turn coaxes a token effort and the third turn sets up a series of events culminating in a clean, efficient start..
the things in common seem to be this..it starts third time when its playing up..other than that, it starts very efficiently..once started, there are no further pauses etc on subsequent starts..other than after a period of weeks..the dash lights are always bright..but i cannot say wether they dim on turning the key during the "playing up phase" as i'm usuallt too shocked to notice..all dodgy starts have been morning starts..(not that i'm blaming mornings of course, but you know what i mean)
I'm going to get new batteries anyway..one is still an origional, so i guess another winter might take its toll..About a year ago, i had a new ignition barrel put in by Toyota, after getting my key well and truely jammed!
But..is there anything in my description that strikes a chord with you fellas? cause frankly, i don't know what to think..If i replace the batteries, i'm sure she'll start well, but i guess she'll also fire up without drama if i were to empty the ashtray..
as always..any pointers will be appreciated.
