Hi all
Just installed a new head unit the other day, install went smooth thanks to the great guides and advice already posted. Question i have is should i change the back speakers for 6x9's or fit a sub?
I'll explain my existing setup. Aiwa head unit 4x45w running the front speakers (Pioneers, not sure which ones exactly) and the back ones (presumably running off the built in amps, haven't had the panels off to check yet), tweeters above the rear door not working. Everthing works fine, rear speakers work on CD, have to press TA obviously. Anyone know how to avoid the travel announcements popping up in the middle of your favourite CD or do you just have to keep flicking back?
I have an amplifier and 6x9 speakers which came out of my old car and i figured i'd use in my surf.
Question is do i replace the back speakers with the 6x9's directly, running off the built in amp?
Replace the back speakers but use my amp to run them, could then possibly mount them somewhere else and use them as well as the existing rear speakers?
Use the amp to power a sub and ditch the 6x9's
Was thinking about an under seat sub unit like the Alpine 1600, anyone use one? know if they're any good? Didn't want to do a sub box in the back as i use the load space for work stuff.
Any thoughts or comments would be appreciated if that lot made any sense to you
Many thanks
Many thanks
