Sometimes when I raise the window (either off the key or the switch), the lock does not engage & I get the warning light on the dash - I'm usually in the habit of pressing it down manually before raising the glass; this doesn't result in any problems lowering the glass again.
However, yesterday I must have raised the glass without manually pressing the lock & I got the warning light. For no other reason that the light was bugging me, I stopped & lowered the glass half way so I could reach in and press down the lock.
Job done, the warning light went off - then disaster...
When I went to raise the glass again it went nearly to the top then stopped going up. I could still hear the motor turning but not movement.
I pressed the switch the other way & the glass went down a tiny bit then stopped, though again the motor was still turning.
A combination of encouraging the glass up by pushing on it & the key allowed me to get the glass fully up so I could get home.
But now I need help to sort out what's gone wrong.
The window won't go down now, though I can hear the motor.
I cannot open the tailgate because the lock is active.
Having taken off the panel from inside I'm none the wiser - operating the switch still allows me to hear the motor, but I cannot see anything trying to move.
Can anyone help me please ?
