I apologize for sticking another thread up as I know there are lots on here ( I have read them ) but I am still unsure as to what my actual problem is.
My rear window has what I would describe as an intermittent problem as my rear window will go down and up with the centre consol control switch then all of a sudden stop working. For example yesterday it was not working at all then this morning when I 1st get in it it worked up and down no problem only to stop working half an hour later.
I hear the CLICK at the back with both the key and the switch inside but nothing happens.
I took it to the dealer I got it from and they told me it will be the relay that is faulty. Only thing is its £241 to buy which I dont have spare at the moment.
Can anyone offer 1) advice or opinion on the fault and 2) a good place to look for a better priced option ?
Its a 95 plate SSRX 3.0 TD Auto.
Could it be wiring as apposed to the window motor control relay ? If the relay was buggered would it not stop working altogether ? The intermittent factor casts doubt in my mind hence I am asking you guys on here who know far more than I do or am likely to.
thanks
Andy
thanks
Andy
Still the click when pressing up on the switch and nothing on the down press of the switch.
