Anyone know if i can pick a feed from the reversing lights near the front or in the cab, ie:- do they opperate from a switch on the shifter or the gearbox?
reason for this is i'm fitting two of those 3 1/2" spotties to the rear spoiler and want switch em to either comeing on with the rev lights and be able to
switch over so they come on with ign off (live feed) and of course off altogether position, i know i can get a feed from the back end and if this proves easier then i'll do that, it may involve two switches as i need two seperate feeds (to a relay) one from the rev lights and a batt live,
i have got a bank of rockers in the overhead console and if memory serves they have 6 pins, got to do some testing with those, if they prove to be two circuits in one switch then they'll be ideal and i can use one switch to do the job, sort of - centre pos - off, left - rev light feed, right - live feed,
I'm posting in the right shop you'll notice
) to two in some split convaluted tube,
