hi all
Iv just had the air con re gased and second hand pump fitted.
Only problem it wont switch on...
But works fine if you jump start the pump.
is there a temp swich which wont let the thing run as its 2c outside?
many thanks
andy
its a 2.4 td 1989 mk2
many thanks
andy
 AnDy
 Do a search from the forum homepage on Air Con Fuse and you will find it.
