Well, I am a convert. Got my first Surf a couple of weeks ago and you can't get me out of it now. I want some snow to get the 4x4 mode going!
Wonering if you fine folks can help me. I am having a problem with the Open Door Warning Light. When I am driving along it tells me that a door is not shut properly (trust me they are). However, when I am loading up the car and the engine is off, the light is off and duely comes on when I open any door and then goes off again once it is closed.
Any ideas. Not causing any particular problem other than annoyance while driving and of course that doubt in my mind that maybe there is actually a door loose.
Thanks.
Thanks.
