being useless at soldering is there anything i can use to connect an inline fuse to my + terminal on battery and then onto my cable, i'm putting extra cigarette sockets in the boot, one on each side of rear pillar, is it ok to use one battery for one side and other battery for the other ?, i've been warned Scotch Lok connectors are pretty useless
extra sockets
Originally posted by joker??maplins
http://www.maplin.co.uk/Module.aspx?...ette&doy=14m11Paul </Slugsie>
Immortal.so far!
http://www.workshoponline.co.uk/sear...+ORDER+BY+code
they are for marine applications so are a bit tough and keep out all moistureBunkle
Fox Hunting is Dangerous
Get 4 in a row, surface mount with two self tappers into plastic trim. cut square hole and fit standard Toyota rocker switch ( just for safety's sake).
Halfords :-( do 4 in a strip for about £5 with an LED so you can see if they're on in the rearview mirror! Run cable each side and make all connections inside the trim, plenty of room. I've got 12v in nearside rear pillar and 250v in offside via an inverter. Make sure all wiring is butch enough and fuse both + and - at 20A to make them useful.Yes! It's still in the garage. M1ROD
Originally posted by SlugsieGot a part number? The only ones I've found there aren't surface mounted.
anyone want the apple core ??Only Toyota can get you out of shite
