hi can anyone point me to the right place,i am looking for a fog light switch to put in the center consol of my surf as was told on the mot it was in the wrong place.there is just a coin holder there at mo so im going to swap it place. model kzn130 if that helps,already tried breakers on ebay.cheers
fog light switch
Hello mate. I have never heard of a fog light switch being in the wrong place!! I am sure somone on here will say different if I am wrong. My switch is just under the steering wheel by my right leg. Its just a standard switch that lights up when the fog lamp is on. It may be the MOT tester was being a bit piccy. Where is your switch and did he fail the truck on it?Originally posted by madmaxhi can anyone point me to the right place,i am looking for a fog light switch to put in the center consol of my surf as was told on the mot it was in the wrong place.there is just a coin holder there at mo so im going to swap it place. model kzn130 if that helps,already tried breakers on ebay.cheers
ColinSWIFT AND BOLD
mornin' m8
just popped into the local garage and had a chat with the Mot tester there (top bloke called dave, but that's not important)
He tells me that the guide on foglights is dead clear and what they have to check is:
1. the switch can be easily & safely reached from the driver's seat (that's why they shouild sit in the car to use the switch)
2. the switch has a light to tell you it's on
3. the foglights work (if you have more than one, as long as the offside one works, it should pass)
hope this helps
ta
hawaiiI'm not overweight, I'm undertall!
Mines in the same place, little round one with indicator light on, praps Madmax's is in a place where the indicator could not be seen.Originally posted by charvellHello mate. I have never heard of a fog light switch being in the wrong place!! I am sure somone on here will say different if I am wrong. My switch is just under the steering wheel by my right leg. Its just a standard switch that lights up when the fog lamp is on. It may be the MOT tester was being a bit piccy. Where is your switch and did he fail the truck on it?
Colin
Laugh!!! I nearly bought my own beer.
Paul
hi yes it's has been put down under steering wheel down on the right hand side, but it is so far down that panel i think he had trouble seeing it was on.it didn't fail but he put it on the comments/recommend page,when i spoke to him he said it should be moved to center consol.
Originally posted by madmaxhi yes it's has been put down under steering wheel down on the right hand side, but it is so far down that panel i think he had trouble seeing it was on.it didn't fail but he put it on the comments/recommend page,when i spoke to him he said it should be moved to center consol.
Mine is fitted under the idle up and suspension switches and it passes the MOT every time!
That's where the one on my 2.4 is, and never a comment come MOT time.Originally posted by madmaxhi yes it's has been put down under steering wheel down on the right hand side, but it is so far down that panel i think he had trouble seeing it was on.it didn't fail but he put it on the comments/recommend page,when i spoke to him he said it should be moved to center consol.Paul </Slugsie>
Immortal.so far!
being a mot tester myself i can honestly say ive never failed a vehicle for a switch being in the wrong place!!as long as its secure,accessable from drivers seat aand has a 'tell tale' fitted it should be fine...jobsworths like that give us a bad name ha ha.. also the fog light itself doesnt have to be fitted to the offside (drivers) side it can be in the centre as well!DONT RUN WIV BIG DOGS IF U CANT PI** UP TALL TREES
Far as I know, they don't have to be off if the other lights are.Originally posted by mark g8awonever heard of a right or wrong place as long as it is wired with the lights so it does not get left on when the lights are not on....shame the manufacturers do not make the lights disengage when the lights are killed...
