My A/C died a while ago i assumed it was a gas problem but had a guy out this morning to check and the gas is fine! but there is no power to the system, if a put a wire direct to the clutch on the pump its works fine, i have ben trying to trace a power source but getting nowhere.
does any body know if there is a fuse or where the realys are for the A/C?? i looked in the haynes manual but none of the wiring diagrams are close to whats on the vehicle! which is a 1990 2.4td surf.
any help will be great
Baz
Baz
