Right , I have repaired the split speaker cone and all sounds good so far .
Next 2 questions for the audio experts is
1) an amp with 2 inputs and 4 outputs , can this have 2 different pairs of watt speakers on the outputs .
2) can more then 2 pairs of speakers be put on the same output , if so do they have to be the same watt .
I have the possibility of a 8 speaker set up , the front pair with no amp , and 3 pairs of speakers in the back off the amp with different watts ?
