Still reckon this would do it then.
Have you got a little more detail on the speakers...?
What can you squeeze where...?
run the front speakers with a full range signal...
Low pass the rear speakers (off the head unit rear speaker output) with a 275hz low-pass filter... 2.3 mH coil on each positive feed to each rear speaker.
(http://www.the12volt.com/caraudio/crosscalc.asp)
Run the amplified rear speakers with 100hz low-pass filter... 6.3 mH coil on each positive feed to each rear... Halfrauds may have these... if not try New Image Car Audio in North Harrow, ask for Charles, tell him I sent you...
This will give you a full range amplified front speaker setup, lower output rear fill (for ambience), then amplified rear bass to add to the fronts... (and rears)... all directional information should come from the front speakers, with sound enforcement from all the others... (at least at the mid-bass frequencies which car interiors suck out of a sound system.)
101 on crossovers and filters...
http://www.xtant.com/html/techSuppor...ersFilters.cfm
