hi chaps
i have a 3.0 auto hilux with the 1kz-te motor,whitch wont start it turns over but there,s no juices 2 the heater plugs or the pump valves. i need 2 find the ecd relay and the spill valve relay so i can check wether there is power to the coils then wether the neg switch is comming from the ecu we have a manual but the ecd relay (identified from fuse box lid) has completly different colours and no pin configuration on the relay (four conections two n/o contact and two for the coil wires) .
ps i have hot wired the pump and heaters and it does run of a fasion
,this is making my head hurt lol .
cheers dreado
cheers dreado
