does anyone know how to replace an actuator on the rear o/s door. it's doing my head in. cheers
actuator
Originally posted by gaffer39does anyone know how to replace an actuator on the rear o/s door. it's doing my head in. cheers
Hi
Please fill in your profile so we know what you are driving. What are your symptoms? by actuator I am assuming you mean the electric motor. If so has it stopped working or is it just very slow? If its just slow your fix is to lubricate the rubber with sillicone lube.
Supply more info and we can help.
Al.I used to have a surf me!
Al.
Originally posted by gaffer39when you open car with key, o/s rear door button doesn't go up. you can hear the motor as if the cogs are not gripping. tried to get motor out but it's a pain in the rear end. must be a simpler way. cheers.
Peter (north ayrshire till next month)
