My surf as problems when cold starting it run very rough for anything up to 20 seconds with a lot of black smoke from the exhaust I renewed the glow plugs but the problem is still there its ok when hot
I have also checked the feed to the plugs 10.7volt then drops to around 8 volts when the buzzer sounds
Yesterday it would not start and flattened the batteries very quicky I have recharged them and It started after many attempts again running rough for several seconds could this be a battery problem they are the original ones and are now 15+years old
