Hi Maurice sorry to bother you again, When you changed the leds in your heater push buttons did you add resistors or are they built into the PCB,
I've finished the heater and was ready to put it back in today but then
decided it was too cramped with all those wires jamed in (dangerous) so i've
stripped it down and am in the process of butchering those clear plastic bits
to give more room for the wireing,Also the push button symbol lighting was
a bit haphazzard so im running individual blue leds behind each button and thought i might as well replace those existing dim leds while im at it,
Many Thanks Mate Ian
