After flooding the surf last thing not working still is the horns, pulled multiple strands of hair out, help needed!
I've got 2 horns, one either side of rad
Steering wheel switch works, gives 12v across fuse when pressed
Horns work and are earthed correctly, if i bring 12v direct from battery they work.
all other nearby electricals work inc hazard lights
Is there a relay between fuse and horn that could be shorting? I've checked for other posts and tried looking at wiring diagrams but am none the wiser. Getting desperate please help!
many thanks
Neil
many thanks
Neil
