Spot Lights Again
  • #61
    Hmmm,
    Brain not fully functional. brightness control turned down....
    will try to read later....
    • #62
      Looking a bit starship Enterprise there Ian!
      Hi Vince, Yeah!, Cant get the warp drive to work either, But one day i might be able to boldly go where my surf has never gone before- up the motorway,
      • #63
        Originally posted by Medieval Dave
        Hmmm,
        Thats OK, I should have gone on the lash last night instead of messing about
        with this, After one or eight pints all would have become clear, Throw a
        match in and phone the insurance co! Will poke about at it today and post any progress this evening, Sorry about the drawing! my son scanned the
        redrawn one but i cant get it to load on atachments, Cheers mate and
        Happy New Year,
        • #64
          OK, I can just about work your diagram out but I cannot read the text, even when i zoom in, but here are a few thoughts.
          1. your power curcuits (from fusebox, through relay contacts to spots) look fine, and it sounds like they are, or you would never get any spots on at all
          2. the feed from the sidelights looks fine except i couldn't work out what the other bit was for, where it splits at the fuse and goes back up to a seperate terminal by the fuse.?
          3. Illiminated switches are tricky buggers, they can be setup different ways. if you can i would leave the illumination bit out of it for the moment. LED types are particularly awkward because generaly they only work with the current going through one way and can do odd things if they are in backwards.
          The thing to do is to try to simplify the problem and look at it a bit at a time.
          Look at just one pair of spots.
          first I would completely bypass the switch. you have the live side of the relay coil connected to the sidelight circuit. put the other side straight to earth and you should get the spots on with the sidelights or mains or dips on but not with no lights on.
          second take that earth wire and connect it to your tapping on the main beam circuit. you should now get the spots on with the mains, but not the sides or dips. your dash main beam warning light should still work hopefully.
          third, add the switch back in.
          hope that makes sense, sorry it;s a bit breif, I have the baby on my lap and she wants to eat the computer.
          • #65
            Weh Yeh Sorted, This neg switching made me distrust my own testing, Try'd
            several things this morning to no avail like changing the relay switching
            round on pins 85 &86, Thinking about it over me chickin roll and tea, When
            i tested the Red/green wire i got a live only on when hi beam is switched,
            So- Neg or Pos switching it does work wired like this=
            Tapped into the Red/green wire with an inline 3amp fuse to supply side of
            all (23456, looped) switches, (remember 5&6 aint used yet)
            From load side of switches run seperate wires to pins 85 (relays),
            From pins 86 (looped to all relays) run to earth, I left the fuse in place which
            is a 5amp (will replace with a 3amp when i get some) So this earth is running through a fuse then to earth (could'nt be arsed pulling it apart, too many fuses are better than not enough i reccon)
            Reconnected side light live to another fuse (5amp, 3 when i get em ) and on to switch 1 for leds, All leds are now working now,
            So looking at the pic the fuses run as follows (from nearest)
            5amp, relay switching, (The red conn you can see is from fuse to earth,)
            15amp, pair spots
            5amp, leds
            Every thing seems to work ok and nothings caught fire or gone bang,
            Question is have i got neg switching or not, Hope this may be of help to
            anyone else thinking of doing this, Cheers Dave Regards Ian.
            • #66
              I look forward to seeing the night time 'full frontal' with all the lights on!
              • #67
                Hi Dave, As requested, LEDs, Two, Four, and full frontal, Cheers mate,
                • #68
                  Very Nice...
