How the lights on a surf work
Starting from the left/bottom depending how you hold the page. I will refer to the lines as 'rungs' now and again, see how the lines look like rungs of a ladder?
1. The first rung is the main light switch. When you turn it on by twisting the stalk by the wheel, it connects to earth and allows current to flow from the battery, through the relay coil and to earth. this energises the headlamp relay.
There is also a bypass that puts the headlamp relay on when you flash the lights.
2. The second rung is headlamp power: When the headlamp relay has been energised, it allows power to flow from the battery to the headlamp relays and from there to the common of each lamp.
If the switch is in HIGH is shown then current flows through the high filament of each bulb then down through the switch to earth. But (and this is the tricky bit) a small leakage current flows through the dip filaments and on through the high beam indicator lamp on the dash. this route will only allow a small current to flow, enough to light a dash light, but not enough to light the headlamps It's not vital that this bit makes sense, but I spent to much time training apprentices.
If the switch is the other way, in DIP, then there is no earth on the HIGH filaments so they go out. there is no a proper earth on the dip filaments so they come on. and the tricky bit... there is now an earth on BOTH sides of the dash main beam warning light, so no leakage current and that goes out too.
3. The third rung I have shown is the sidelight rung. it is similar but simpler. As you can see the control circuit (through the coil) is a negative switched job again, but tho power side is a conventional positive switch.
When the switch is on then the relay is energised. current flows through the relay then the fuse, then through all the assorted tail, side, no.plate, dash etc lights.
I Hope that makes sense, am glad to try to explian more if I can. sorry the sketch is a bit rough, but I lost patience with it.
When I get my breath back I will post how to tie in fogs and spots and why.
Dave
Dave
Right Think i've got it through the thick crust,
