Problems when starting
  • Problems when starting
    Can anyone help me?? My surf 91 starts ok when cold, but after driving around a bit then start again, it does'nt want to start straight away, I have to turn ignition off and start again, sometimes it will go other wise it takes a litlle longer. I have replaced glow plugs already.
    Thank you to who ever can help!!!!
    Have you got any kind of immobiliser on it? could be playin up when warm
    THE ORIGINAL CRAZY BITCH!
      Other possibilities........Dirty air filter, or air in the fuel.
        Thanks, I have replace the air filter. How do you remove air from the fuel filter?
          Hi, I have a new immobiliser installed, it was doing it before but not as much as now...
          Thank you
            you can try and undo the tap on the bottom of the filter and prime it by pumping fuel through with the pump on the top of it.
            Tim
              Thanks, I found the tap, and I'll give it a go......
                if tht doesn't work try losening the jectors as per below:
                loosen one
                turn engine over untill fuel comes out
                tighten
                loosen next
                turn over engine untill air comes out
                tighten
                etc etc
                do this to all four
                Joe112
                Paranoid? They're out to GET YOU!
                  Thank You To All That Help Me Sort My Problem... It Is All Fixed, No Problems To Start Now...... Thanks Again
