My wife tells me that the rear window has packed up.
I did a quick check and found a fuse had blown (under the bonnet the smaller of the two black covers, there is one 30amp fuse between two relays)
I assume that this fuse is for the window?
The reason I question this assumtion is that the cover had CVS FAN (or something similar) written on it.
If it isn't the window fuse what is it, and more to the point where is the rear window fuse?
TIA
TIA
[/color]
