not sure what the story is with this alternator! On the top there is a bolt with what looks like an earth lead attatched. This lead keeps burning out! at the moment i have a croc clip holding the wire in place, well whats left of it! even the croc clip is slowly melting away! when it melts and leaves a gap in the connection all the lights on the dash come on and the voltage indicator drops? Now i know this happens when the alternator gets wet, but what would be causing it to burn out all the time?
burning out!
Originally posted by speedymacfishnot sure what the story is with this alternator! On the top there is a bolt with what looks like an earth lead attatched. This lead keeps burning out! at the moment i have a croc clip holding the wire in place, well whats left of it! even the croc clip is slowly melting away! when it melts and leaves a gap in the connection all the lights on the dash come on and the voltage indicator drops? Now i know this happens when the alternator gets wet, but what would be causing it to burn out all the time?
Is this the original earth lead for the alternator.If not then it may not be a heavier enough gauge.Earth wires will get very hot or melt if not making proper contact or too light a gauge for the job.If you are sure there is no wires shorting on the alternator try a heavier gauge wire.If this still gets hot then check for faults elsewhere.
Neville
