Originally posted by Mike66
Remote Central Locking
Paul </Slugsie>
Immortal.so far!
Originally posted by SlugsieNo, can't get the damned thing to work. It's got power, it's relays trigger, but the locking doesn't fire. Doesn't help that the instructions aren't exactly clear or relate to how the Surf is wired. Might have to get a mate of mine (who is an electronics engineer) onto it.
Had any luck with this yet???It just does, OK?
Originally posted by dave.j.robboHad any luck with this yet???
I eventually got it working (the problem was that I had shorted it out at one point and blew a couple of tracks on the circuit board, quick solder later an all was well.)
I basically used a multi-meter to figure out how the kit worked. Following the second wiring diagram IIRC, I got it wired up with a slight adjustment for the Surf. One of the wires that the instructions says to wire to the power feed I connected to earth (can't remember which, but if you have a multi-meter it's easy to find out), I did this because the Surf uses a negative switched system instead of live switched which is more usual. I then attached the two output wires to the wires that come out of the door switch. There is a post somewhere by I think it was NedNil that gives detailed instructions about which wires to connect to. After that it all worked. I still haven't wired it up to flash the hazards yet, may get round to it at some point.
Hope that helps.Paul </Slugsie>
Immortal.so far!
