Hi I have just bought a 92 2.4 TD Surf.I have a few questions for you, which i hope can help me.
1. Rear Fog light. There isn't one i can see, no switch on dash etc, or any broken brackets. The car has an MOT done in September, is this a legal requirement for the UK?
2. Heater control lights. The background lamp on the cold and hot display isn't working, is this a simple bulb job or difficult. I've had the dash apart and couldn't see how to change them.Is the bulb easy to change. Also on the bank of buttons that direct airflow, should these be lit when the lights are on or only when you press them to direct airflow? If the bulbs are blown, is it easier to change the whole control.
3. Rev counter. When i bought the car the needle was below the stop. I removed the clocks and relocated the needle to its rightful place. When i switch on the ign, it jumps atraight up to 3000 rpm and operates between 3 and 6. Is this a common problem and if so, what is the fix?
4. Finally. The leccy aerial is broken, i've been quoted over £100 from Toyota for a replacement. Is there a cheaper option available? Are the aerials easy to fit - say 2-3 hours max?
Hope you can help,
many thanks
Brad
Hope you can help,
many thanks
Brad
