Right, please bear with me for this...
Has anyone tried the dip/head light modification where you run the power for the dip/head's directly from the battery using relays and use the stock wiring to switch the relays. If you use heavy duty wire you are supposed to have much brighter lights. I have poked around Yotatech on this and a lot of people reckon it's a great mod, especially if you have good bulbs.
I run Phillips Vision Plus bulbs and they are very good, pure crisp white light and a free set of super white side lights.
So has anyone tried this??
[size=4][color=#00ffff]SSR-X 1996 3.0 TD !!! ESSEX BOY'S RULE !!!!!!
