Hi All,
I aquired my Surf on Saturday, 2.4TD SSR-X, imported '93 in Grey. I'm quite pleased with the condition of most of it, and have spent most of the day fiddling and getting to know it a bit. The main problem that I have found is that the Air Con and all the heater switches appear to do absolutely nothing whatsoever :-( They look as if they should illuminate when depressed (but they currently do not), and nothing at all happens to the change in air flow. There is no change in engine note when the Air con is pressed, and no apparent cool air produced.
The Dash has a number of screws missing.... I imagine the guy who fixed the fan (I spotted that when I was buying the thing) was a little heavy handed!
Does anybody have any ideas of a quick fix or simple solution? I hoped that it might be a fuse, but have only found one fuse box so far which did not appear to be involved with the heater. Any suggestions gratefully received.
Cheers,
'Drew
Cheers,
'Drew
