Piston down (compression)
  • #46
    hi chris, hope these pics are clear enough.
    i only neen 1 of the intlet manifold screws, though is you can find more it would be helpful, just to be sure. also its not a philips fitment as can be seen in the pic its a star drive and a 10 mm.
    the exhaust manifold bolts however are very important, as can be seen in the pic they are a stud with a nut on the end, the nut tends to sieze and this is fine, see the pics to know what i mean.
    if you could get them sent out next day delivery tommorow i'll be smiling. thanks alot mate let me know whats happening.
    cheers
    jay
    If you pretend it goes fast... it will!!
    • #47
      this is one crack across the two valves.
      comp isnt letting me do the other picture, so will try again later.
