New Engine Required
    HE's in L A. USA
      V-6 Engine
      Hi if yours is still running spend the money on a rebuild.
      Live Life To The Full
        V6 engine!!!
        No engine is not worth it,too far gone...
          If you scrap it let me know please, there are some bits I could do with
          NO WORRIES!
          Rusty
            parts
            SAME HERE
              V6 engine!!!
              Yes I will. The heads are reconned and everything else is ok. Ironically I have never encountered the heads to be unserviceable on a 3VZ-E. I have rebuilt countless numbers of these engines and heads are always good!
                http://www.engineconversions.co.uk/toyota.html
                cheap kit for mating the v8 to lux box if you need a rover v8 engine call me and ill sort it out 430494
                good luck
                ITS GOOD BUT ITS NOT RIGHT ?
                  Found somewere nice and snug to tuck it up. Fed up off working outside. Am now going to completly strip and poss bore out a bit. I'm like the Million dollar man (we can rebuild it). Tell you what though I could do with a complete back window mech as i have stripped mine down and it's as rust as F*$K.
                  Any clues on were i can get one.
                  • #24
                    Think you'll find the motor is the same as used in the doors on Toyota Corolla etc.
                    Think you need the passenger side unit but do a search on here as it's a common problem.
                    • #25
                      Hi Geoff how did you get on with the motor any takers.
