Gearbox now hooked up to engine and all in place
Final position tweaking to be done before mounts are made.
Just have to ask around for some measurement opinions etc. Make sure it's all good.
Thankfully the rear prop extended/stretched enough to take up the 30mm shortfall but I don't think I can compress the front prop 30mm. Need to check the rear prop is ok to be extended/stretched 30mm.
Once all mounts are made I can finally dismantle and start the clean-up
