very nice looks the part! guess that wont be getting muddy in a hurry! its great when the works you have done yourself pays off!
Karma Supra's HiLex
Originally posted by Ultimagtr21 View PostKarma,
On your exhaust system, have you used any flexy joints at all? Also, where did you get your exhaust parts from? Did you weld it up yourself?
Most here probably won't bother with the cats anyway, but the VVTi management throws a wobbly without. Yes it was designed and built by myself and a pal that's a good welder... he deserves the lions share of the credit!
Its pretty loud
Originally posted by Paul ssrg View Postwow this this is awesome!the exhaust is a work of art!
Updates:
I pulled the sump off the gearbox a few weeks back, removed the valve train and shimmed the shift accumulators 8mm, raised the overall gearbox line pressure, fitted a new TC lockup solenoid (it turns out the old one was ok, the gearbox is just a little tired) and put two loads of fresh gearbox oil in, with some Lucas "non slip" additive that the supra lot swear by for longevity/ handling power
I adjusted the line pressure cable so it was a little more aggressive, and it definitely pulls a little harder and shifts a little crisper now.
I also have fitted some new Depo crystal headlights, sidelights, and bumper lights, and some uprated bulbs, it now looks a lot sharper at the front, and I can see at night! (I have pics on my home PC, but I'm stuck in a hotel at the other end of the country)
Also I really need an LSD.More Lift.
More Tyres.
More Engine.
a supra or soarer lsd in standard form shouldnt be too hard to get...then just get a rebuild kit for it.I know lads who have done this with corolla factory lsd's(gt coupe) and they rckon they were better than any of the top end like kaaz,cusco etc[B][FONT="Impact"]Cut my way in...weld my way out![/FONT][/B]
Originally posted by Paul ssrg View Posta supra or soarer lsd in standard form shouldnt be too hard to get...then just get a rebuild kit for it.I know lads who have done this with corolla factory lsd's(gt coupe) and they rckon they were better than any of the top end like kaaz,cusco etc
I've been hunting about for a decent Landcruiser Prado rear axle.. with the Non E locker and ABS, so I can rebuild that to have a (working) LSD, and benefit fro the rear disk brakes..
Not to many about though, they are all E lockers!More Lift.
More Tyres.
More Engine.
