Having a bit of a problem starting #7 at the moment.
Quick overview of whats happening and what I've noticed. I've been reading up on Lextreme as I'm keen to learn but thought I'd run it past you or someone else who is reading this and knows what they are talking about.
Fires up then instantly dies.
Fuel pump then runs for a lot longer priming than usual before light on dash comes back on once pump stops.
In the engine bay this is what I noticed.
Fuel pressure dampener screw shoots up and there is a load of hissing coming from it right after someone else has tried to start it for me.
Up until this there hasn't been a problem with starting although I have been messing about with the restriction in the hose to the ISCV.
