Hi Vince,
Do you use the Lexus engine mounts (the rubber bit) if not have you got any I could buy off you, as I've just pulled one of mine apart taking the engine out to weld up the tacked on chassis mounts
Mark.......
Mark.......
Hope the weather has been kind and you and the family are having a good break...
I'm kind of commited to the Lex ones now, so if you have any could I buy some off you?
revving smoothly. I have the 20mm ID vacuum pipe that comes out of the front of the plenum chamber attached to the air intake between the MAF and Plenum, I did have this pipe attached between the MAF and air filter, but it didn't run well at all. If I pull the plug of the MAF it runs and ticks over fine, all though very rich! Is there anything else I can try to get it to tick over smoothly?
your a star, will get IACV off and give it a clean.
loving that Lexus v8 noise and power
I do have one question though, is all that clicking coming from the ECU normal? sounds like a couple of relays switching on and off?
