Lexurf V.
  • Originally posted by BUSHWHACKER View Post
    How's yours running?
    fine thanks why do you ask?
    • Originally posted by lord lucan View Post
      You asked first.
      • sorry did i ask you , deepest apoliges
          is your engine not running properly?
          aye it runs fine - i just got a new scanner and was playing around
          • Mines rough.
            Non intercooled nothing.
            • Originally posted by gwh200 View Post
              Mines rough.
              But how's the Lexurf?
                Mines rough.
                Why?
                  Why?
                  cos he leaves it festering round the back in the rain letting all the leccy bits get damp
                  • Well when I startup, it's a bit rough. If I try to drive away, it feels like the box us slipping. If I park facing up hill, it won't go into reverse at all. Fluids are fine, but I desperately need bew leads, and I'm still unemployed...so when I get sone work.
                    It's actually all fine, but needs using a bit more than it gets at present.
                      Make bure the kick-down rable is adjusted correctly, there's a small hubber marker on the inner cable, it needs to be just visible at the end of the outer sheath.
                      I can type using the back of a spoon too!!!
                        i tried my kickdown cable adjusted in and out - it makes a huge difference to the gearchange.
                        ive got about 1mm of the rubber doodaah showing now and the changes are super smooth. i changed the filter and pumped 15l of the toyota atf through it as well.
                        • Sorry...an excitable Fred on my lap!
                          I still need to put my new caps and rotor arms on as well. It's all ignition based, damp issues. After a few miles it's running fine. I do have a leak again though. It's where the heater hose goes through the bulkhead. I've got an insert for the copper pipe. I just need some time on it. Ive run it for 6 months and hardly touched it!
                          • ecu hidden
                            after 10 hours of soldering the ecu is now in the glovebox cuddling the relays and fusebox. i now have a glovebox that holds 2 postage stamps and half a pencil but its a bit neater.
                            it gives easy access to the fusebox, relays and the ecu.
                            i thought about moving it under the seat but it would be a real pain having to take a seat every time i want to fiddle with the ecu.
                            • Originally posted by gary-r View Post
                              Very neat.
                              There's guy on Lextreme that has extended all 80 odd wires of his loom just so he can fit the ECU behind the seats in his pick-up. Took him six hours apparently.
                              I'm going to look at creating a glovebox or cubby hole in the top part of the dash if possible.
                              Changed my mind about trying to get the Lexus dash to fit, it's never going to look neat however I do it.
                                Thats excellent gary.
                                I do have all the plugs that go into the ecu. Its a simple unplug/replug to move it anywhwere, on its 6 ft of spare cable.
                                i took it for a spin today. Its all ignition/damp/bad cables/poor dizzy caps...i could go on.
                                I need some sunny days and a bit of mojo....
