has any1 ever thought of fitting the 4.1 turbo diesel from the above bus to a surf?
toyota optimo
Originally posted by BUSHWHACKER View PostNope.
Is it an in-line six? If it is it won't fit without serious modifications to get the radiator in.Surfin on the tidal waves of mud!
Originally posted by BUSHWHACKER View PostNever heard of the swap before.
I imagine it's a very heavy lump of iron to be shoe-horning into a Surf though, the 2.4 engine is heavy enough!Surfin on the tidal waves of mud!
Originally posted by BUSHWHACKER View PostMore power + more weight which means the suspension and braking will suffer, so thats two more areas that'll need upgrading.
Why a diesel engine swap anyway?Surfin on the tidal waves of mud!
All 60 series, some 70 series and ALL 80 series had 6 cylinder diesel engine.
60series stopped production in 1989, 80 series stopped in 1997, 70s began production in 1984......... so they are OLD landcruisers, only thing older will be a 40/50 series which used 3.4 litre 4 pot and some 5 pot mercedes diesel engines.
So "old big Landcruiser" did have 6 cylinder diesels, optimo/ceatano use a Toyota 1HZ 4.2 litre S6 engine.http://www.4x4xfaz.co.uk
