cut the bulkhead/floor
or just buy a LC80!
(i have 2 available)
or just buy a LC80!
,It will fit. As vince said it will need some heavy modification to the (bulkhead maybe depends how you do it.),floorpan, suspension and brakes.Im gonna be doing a straight six swap into a surf in the near future,using the 2H 4.0 OHV DIESEL ENGINE. allthough this will be in a 1st gen,so i would suggest you uprate the torsion bars, and dampers up front,the surf uses four pot calipers but i would upgrade to bigger discs and calipers from a 3rd gen,(again these wont be a straight swap,as the 3rd gen runs on 16" rims) and uprate the rear springs.You will need to fabricate new front and rear prop shafts,engine mounts,gearbox x member,modify the sump ( i dont need too as the 1st gen is running leaf springs and has a massive lift.),rad mounts, if you keep it in the front.One idea im toying with is an electric water pump and fitting the rad in the rear,using two kenlowe puller fans and modifying the body work with an air scoop and rear vents, this will allow the engine to be fitted forward a good few inches,so that the bulkhead will not need to be modified as much.Lifting the body a few inches will also aid in fitting as this will give you so much more room between the chassis and top of transmission tunnel,hopefully eliminating the need to cut the floorpan about too much.I would say lifting the body at least 3" will give you the room you need.the 2h bellhousing is much bigger than the 2lte bellhousing assuming yours is a 2.4ltr.as for weight theres not a lot in it,they are both cast iron engines,but the gearbox and trans case on the 2h may be smaller than the auto box and trans case on a 2lte but its a lot bulkier and shorter.Again fitting the manual box you will need a pedal box from a manual surf and a clutch master cylinder.,then you will need to mod the floorpan to fit the gear levers and high and low ratio levers.
