It's almost as if the starter circuit has something wired into it, which keeps it open(obviously). But there's nothing on the starter circuit except starter, battery, relay and ecu. Maybe old immobiliser or something in the original starter circuit ?
Lexurf IV.
Sticking solenoid by the sound of things. If it sticks in, switching ignition off wont stop it. The connection to the starter goes from battery, thru solenoid contacts to starter. The only thing the ign key does is provide power to the solenoid coil itself. If it sticks, it matters not whether there's power to the coil.Originally posted by BUSHWHACKER View PostThis is a weird one though.
Crank engine, engine starts, starter won't disengage.
Switch off, remove key, starter still trying to start engine!!!!!
Jump out, rip earth cable off battery!
Splinters in finger tips from mucho head scratching.
I cant think of anything else it could be.Cutting steps in the roof of the world
Originally posted by Apache View PostSticking solenoid by the sound of things. If it sticks in, switching ignition off wont stop it. The connection to the starter goes from battery, thru solenoid contacts to starter. The only thing the ign key does is provide power to the solenoid coil itself. If it sticks, it matters not whether there's power to the coil.
S'what I/we thought too, but tried a new relay, still the same.
Disconnecting the battery stops it, but when you crank the engine again the starter stays running......again!
I think it's a starter out job anyway, as I'll want to check for any damage and inspect the contacts. Wouldn't want Graham to have to do it, his job is to drive it.
Not the control relay Vince, the actual solenoid on the starter itself. Could also be the return spring on the starter dog is weak. That would hold the plunger in and make the contact until you disconnect the battery, then it would probably release.
Ign switch contacts buggered? you need to check for volts on the solenoid coil feed (without wishing to state the bleedin obvious - the small wire
)when you release the key back to the ign on position after starting. If there's still volts there its a wiring issue. If there isn't, its the solenoid contacts sticking / welding themselves. Assuming its a conventional system, it cant be anything else.
Check the feed to the solenoid first - easier than getting the starter out.Last edited by Apache; 12 September 2010, 22:28.Cutting steps in the roof of the world
Thats wot I was trying to say , but you typed more then me .Originally posted by Apache View PostNot the control relay Vince, the actual solenoid on the starter itself. Could also be the return spring on the starter dog is weak. That would hold the plunger in and make the contact until you disconnect the battery, then it would probably release.
I only suggested it as had it happen before .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
OK, I've sorted it!
Nothing to do with my additional wiring, it was a wire that I forgot to snip.
There's the STA wire (Crank signal) at the ECU that I connect to when wiring my own start circuit relay. Turns out I er......forgot to snip this wire to isolate it from the original start circuit, thus sending a constant 12v feed to the starter solenoid when the engine starts.
Am I a TWONK or what!!!
Well done ProffessorOriginally posted by BUSHWHACKER View PostOK, I've sorted it!
Jess
"Cos short cuts can cost more in the long run"Buncefield Burner
Certainly not!!Originally posted by BUSHWHACKER View PostOK, I've sorted it!
Good bit of discoveryering sir.
Non intercooled nothing.
meanwhile tintin is coming to pick me up and transport me to a while evening of knuckle skinning lunacy. Yup...it's hummer time...well gearbox out and rebuild and transfer case etc etc,
