Lexurf IV.
I've sent mrs gwh to her room with no supper. I found it...in shredded form in the shredder. Let's get it legal and I'll tax it online. I will then get a new logbook in your name al.Originally posted by tintin View PostKeith's doing it at the mo'(cos i'm 50 miles away) so probably pass today!
Will look into the insurance today!..... I take it you didnt find the V5 anywhere!!
AlanNon intercooled nothing.
Cool, no worries mate! Will ring the insurance today!Originally posted by gwh200 View PostI've sent mrs gwh to her room with no supper. I found it...in shredded form in the shredder. Let's get it legal and I'll tax it online. I will then get a new logbook in your name al.
Alwww.amcbs.webeden.co.uk www.xjrestorations.co.uk
Didn't get there!
Bl00dy thing wouldn't start, cranking and cranking, nothing.
Turns out, the fuel pump wasn't er, pumping. I had no reason to suspect it as I've wired it the same as the last one. Pulled all my wiring apart and checked it over three or four times found nothing wrong.
Put 12v direct to pump, nothing!!!!!!
Thought about dropping the tank, but I had just put three gallons of fuel in it, so I cut a hole in the floor!
Sorted now, it was the earth wire to the pump. I connected to an existing earth when I fitted the pump/tank and thought nothing more about it, black wire attached to the body, sorted.
However, that earth connection wasn't sound so no fuel getting pumped.
Just got to connect the power steering hose in the morning then go for the MOT.
