1uzfe into 2.4TD surf
  • its On The Road At Last!
    • Nice one dan.You got any video footage of it all up and running now
      • will do tomorrow think going to need another set of silencers on the exhaust. only have one problem which is the speedo. it works but doesnt it registers something but not the true speed say 5mph for 30 and 15 for 50 mph
        Vince any ideas on above or below?
        apart from that is OK i think the ECU was learning kick down as i was going along then when i reved it about 3000 it kicked down from 3 to 2 then 1 and stayed there?? i thought it might be loss of fluid and was slipping gears but when you put it from P to D it kicks you forward so i think its not loss of fluid??? it seems OK now though had a good drive around but didnt really boot it and was fine? so maybe the ECU was teaching its self??
        • When you go from n to p it does seen to jump quite allot I think they all do it as both the ls 400 seem to be the same!!
          • Originally posted by dannyboy77 View Post
            Have you got the earth and signal wires mixed up?
            It'll take several drives/starts for the ECU to sort it'self out. Don't disconnect the battery during this time as it'll never learn anything.
            The LS400s and Soarers have rubber couplings on the propshaft flange to eliminate driveline shock, the Surf's is solid.
            • Congratulations Dan, look forward to seeing your vid!
              Alan
              • i will have a look at the wiring when i go out and play on it! it was green/red=signal blue=earth & black orange=12v should be OK. it is a different TC as the one was originally on as that broke just before the swap so i dont know if the new TC speedo works i can put the the one form teh broken on in as i know that works but will get to the bottom of it somehow
                another little problem im trying to solve is the solinoid to release the lever rather than using the red button as the brake switch goes into the ECU so got to find the wire that comes out the ECU that gives the signal / power to release it? or is it red button from now on?
                cant find it on the FSM wiring diagrams of either the surf or the lexus
                  Tee off that brake switch wire and connect to the shift lock wiring at the base of the shift lever.
                  Can't remember which wire at the moment, I'll have to go and look at mine.
                  I'm using the Lexus shift lever and centre consol now, but the wiring is the same as the Surf's.
                  • Originally posted by BUSHWHACKER View Post
                    will do that does sound straight forward but it never is will wire that in tomorrow will have a look at the speedo as well if it is wired OK any thoughts?
                    vid is of truck as of now think i will need another set of boxes on the exhuast its a bit too loud! oh and there is swearing all in HD as well!
                    http://s612.photobucket.com/albums/t...t=PICT0011.flv
                    • Sweet sweet music!!!!!!!!!!!!!
                      • Dan that is so so sweet, well done mate. Now a bit of summer sunshine for you to make the most of would be perfect.
                        Brian
                        • Wow !! that's Sweeeeet .... Just how a V8 should sound !!
                          Jess
                          "Cos short cuts cost more in the long run"
                          Buncefield Burner
                          • Sounding awesome Dan!
                            Alan
                            • I concur!!
                              That sounds AWESOME!!! Well done mate. It was definitely worth all the hard work!
                              Mark
                              If it ain't sunk.....it ain't junk.
                              • thanks all! yeah its sounding great takes you mind off the fuel gauge! if its right its about 15mpg but around town its only meant to do 19mpg anyway in the lexus
                                few things just to tweak but its 99% done. hopefully at bala next sunday!
