well its oging OK but the truck is on the path so i am having to work in the day light when its not freezing and raining! which doesnt leave a lot of time! i am doing OK just got to finish the fuel pump wiring and then should be able to fire up! had a bit of a mere getting a generic fuel pump relay but got a cross over relay (85-86 & 30-87-87a) 5 pin and its going in the EFI socket in the fuse box which is unused in the diesel surf! i have also used the glow plug fuse socket(well a 30A fuse from the lexus) to feed the EFI, starter & opening circuit if i remember correctly i will put pics up of the wiring. all in all OK just slow! but we cant all be as quick as bushy!
then drill bolt holes
