OK, finally got the Surf and getting used to it. One thing I've noticed is that the oil pressure seems low. I checked the other threads on the site and found the diagram and while it is within the limits shown, it really is at the bottom end of the range. Oil is fresh, as is filter, engine runs smooth quiet and powerful and no hint of overheating.
So, does anyone know what the actual pressure should be in lbs/sq in or Kg/square thingummy, so i can get it checked out (although not sure what I'd do if it really was low)?
Alternatively, if enough of you join the thread and tell me yours shows low too, I'll probably be sufficiently comforted.
Kev
Kev
Me 2. A quater @ idle, half @ cruising except when cold....I use gloves and scarf?
